laptop with external monitor...how?
Discussion in 'Desktop & Laptop Computers Forum' started by Gordon @ Convergent AV, May 30, 2004.
  1. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,001
    OK I used to be able to use my laptop with an external monitor. I am sure that there was a profile for it that allowed me to do the f3 flip to turn on the external output....However.
    It looks like I may have deleted this somehow. When I go to display settings it only has M6 default single display as an option. If I go more indepth to the bit that shows the CRT or LCD external display options I cannot enable either (presumably as it's in single display mode)
    Any ideas someone? This is really pissing me off.
    G
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    F5 or F8 normally, but often you need to press it twice.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,001
    It used to work Nic it's that the driver or something is now gone or disabled. The key for this function on it is f3 and it's f8 on new one. I am trying to get old laptop to do a presentation.....argh...
    G
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Just thought I would try the basics first incase you were having pre Cedia jitters, damn should stop using that word :) jitter always gets me in hot water ;)
  5. sneaky
    sneaky
    Dec 14, 2003
    348
    16
    North East
    The screen toggle is usually fn(function) and the F5 key together.
    Chris
  6. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,257
    Manchester
    +753
    Additionally the Fn -> F5/F8 is usually a "triple toggle" operation ; for each sucessive screenswitch operation it moves from outputting to laptop-internal , external VGA socket and both enabled simultaneously (then back to laptop-internal and so on).
    It make take a few seconds each time to physically switch the output (and a few seconds more for many VGA projectors to recognise and sync-up to the signal).
    Chris Muriel, Manchester.
  7. Pootle
    Pootle
    Apr 14, 2002
    149
    Staffordshire
    Also note that most laptops will only flip if the external socket has something plugged in, so make sure it is plugged in and switched on before you try to flip.
    What graphics chipset is fitted? that will make it easier to help you
  8. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,001
    I am aware of all these issues thanks though. It's a driver thing I am sure of it. I have brought out an old old laptop and have managed to get it to do what's required.
    Cheers,
    Gordon
