laptop VGA to BNC
Discussion in 'Projectors, Screens & Video Processors' started by tech838, Aug 28, 2006.
  1. tech838
    tech838
    Aug 23, 2005
    80
    Can I connect my laptop directly to a barco 600 with just a VGA to BNC/RGB cable
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Yes, but set the lap top resolution to 640x480 or 800x600 first.
    The 600 chassis might go as high as 1024x768 but it may not look quite as sharp as 800x600.
    I seem to remember that the BARCO likes negative syncs. Others might correct me if this is wrong.
  3. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    I tried with my laptop passed through my Iscan Ultra bypass, but could not get a stable image on my Barco 708 Data.
    I suspect that the sync was not set up correctly VGA - 4BNC. Where should I start out to solve the problem?
  4. stevem1902
    stevem1902
    I am looking to do the same thing with a PC, as I understand it you can just take the output from a VGA card (HD15 connector) and split it up into the seperate RGBS needed to run the projector. I read somwhere that you need to combine the horizontal and vertical sync from the PC/laptop with a BNC "T" connector to give you the correct Sync signal. Maybe someone could correct me on this. You can get the pinout info of the VGA port from the internet, I assume (perhaps incorectly) its just a case of buying/building the correct cable to do the job. At the moment i am just useing a laptop with Composite video out, but i am hopeing for a better picture by useing the RGBS inputs on the Barco.
    keep us posted on how you get on.
    Steve
  5. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    Yeah It can be physically done as Steve suggests,
    Are there any methods of a software driven pin change instead of a physical mod, thus being able to output direct from the Laptop/HTPC by manipulating the software?
  6. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,501
    64
    Norfolk
    +242
    Try Powerstrip. I've set sync polarites (negative) and types using it on my machine.
  7. tech838
    tech838
    Aug 23, 2005
    80
    How do you know if it is positive or negative sync, and does it matter/what will happen if it is positive sync and you leave it?
    and if you do HAVE to change it what settings do i need in powerstrip to change it?
    Thank you
