Laptop VGA Samsung LE32R8BDX connection problem
Discussion in 'Samsung TVs Forum' started by wilkesy, Jan 10, 2008.
Tags:
  1. wilkesy
    wilkesy
    Hey guys, i've had the Amsung LE32R8BDX for a while now, and when i first got it i could connect my laptop up to it no problem. Then all of a sudden about 2 months ago it stopped working. If i turned the TV on in PC mode, the desktop from the computer would flash up for a second, then it would say no signal and go black.
    I found that if i fannyed on with settings and connections for half an hour i managed to get it to work. But now i've just got back from bein away for 3 weeks, and its not working no matter what i do. It still flashes up for a second, but i can't get any further than that.
    The cable is fine, so i dont know what else to do....
    help :D Thanks
  2. paulbrannan
    paulbrannan
    Oct 24, 2007
    130
    +9
    presume you have the res set to something the tv cant handle.
    theres a list of supported res in the manual
