zymoloid1081
- Joined
- Nov 7, 2010
- Messages
- 16
- Reaction score
- 1
- Points
- 2
- Age
- 33
Hi guys,
Im planning on soon buying/creating a new desktop pc and am search for funds.I currently am using a Sony VAIO VGN-AR88E laptop and wonderd how much this is worth.
The specs are:
General System TypeNotebook Built-in DevicesStereo speakers, wireless LAN aerial Width41.6 cm Depth30 cm Height3.4 cm Processor ProcessorIntel Pentium Dual Core T2390 / 1.86 GHz Multi-Core TechnologyDual-Core Data Bus Speed533 MHz FeaturesEnhanced SpeedStep technology Chipset TypeMobile Intel PM965 Express Cache Memory TypeL2 Cache Installed Size1 MB RAM Installed Size2 GB / 4 GB (max) TechnologyDDR2 SDRAM - 533 MHz Configuration Features2 x 1 GB Storage Controller TypeSerial ATA Serial ATA InterfaceSerial ATA-150 Storage Hard Drive250 GB - Serial ATA-150 - 5400 rpm Optical Storage TypeDVD±RW (±R DL) / DVD-RAM - integrated Read Speed24x (CD) / 8x (DVD) Write Speed24x (CD) / 8x (DVD±R) / 6x (DVD±R DL) CD / DVD Rewrite Speed24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM) Card Reader TypeCard reader Supported Flash Memory CardsSD Memory Card, Memory Stick, Memory Stick PRO, Memory Stick Duo, Memory Stick PRO Duo Display Display Type17" TFT Max Resolution1440 x 900 ( WXGA+ ) Widescreen DisplayYes FeaturesX-black Video Graphics Processor / VendorNVIDIA GeForce 8400M GT Video Memory128 MB Total Available Graphics Memory890 MB Audio Audio OutputSound card Compliant StandardsMicrosoft WSS 1.0/2.0, DirectSound3D, High Definition Audio Audio InputMicrophone Notebook Camera Camera TypeIntegrated Sensor Resolution1.3 Megapixel Capture Resolutions1280 x 1024 Input Device(s) TypeKeyboard, touchpad Telecom ModemFax / modem Protocols & SpecificationsITU V.90, ITU V.92 Networking NetworkingNetwork adapter Wireless LAN SupportedYes Data Link ProtocolEthernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g Compliant StandardsIEEE 802.11b, IEEE 802.11a, IEEE 802.11g Expansion / Connectivity Expansion Slots Total (Free)2 ( 0 ) x memory
1 ( 1 ) x CardBus - type I/II
1 ( 1 ) x ExpressCard/54 Interfaces1 x IEEE 1394 (FireWire) - 4 PIN FireWire
3 x Hi-Speed USB - 4 PIN USB Type A
1 x headphones - output - mini-phone stereo 3.5 mm
1 x microphone - input - mini-phone 3.5mm
1 x audio - SPDIF output
1 x audio / video - HDMI - 19 pin HDMI Type A
1 x display / video - S-video output
1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x modem - phone line - RJ-11 Miscellaneous FeaturesSecurity lock slot (cable lock sold separately) Power Power DeviceExternal Battery TechnologyLithium Ion Installed Qty1 Run Time (Up To)1.9 hour(s)
Any help is very much appritiated ,
Thanks , Jack .
The specs are:
Thanks , Jack .
