Laptop USB 1.1 can I adapt to USB 2.00?
Discussion in 'Desktop & Laptop Computers Forum' started by lcarter, Jun 11, 2004.
  1. lcarter
    lcarter
    I have a 2/3 year old laptop which is working fine for me so don't really want to have to get a new one, but it only has a USB 1.1. I want to be able to plus in an external Pioneer A107 DVD Re-Writer, but will need to update the laptop to a USB 2.0. I am sure I have read somewhere that this is possible. Can anyone help - it would be appreciated.
    :thumbsup:
  2. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,368
    Stevenage, Herts
    +151
    You can add a pcmcia card with usb 2.0 if you have a spare slot.
  3. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    It is not possible to physically or software upgrade a USB 1.x port to USB2. The only way to do this is to add a USB2 card (PCI for desktops or PCMCIA for laptops). A full FAQ on the differing specifications is available at http://www.everythingusb.com/usb2/faq.htm
  4. lcarter
    lcarter
    Thanks for your input - just been on everythingusb.com (what a great site) - looks like I will have to check regarding the PCMCIA Card.
    I knew there was a way but didn't know the correct way
    Thanks again
