laptop to tv info
stooo
in very simplistic termonology......how do i connect my laptop to my lcd tv.....vga connectors in both laptop and tv. :lease:
Iccz
Connect the VGA port to the VGA port using a VGA cable (like you use to a normal monitor etc).
Connect your 3.5mm headphones out to the RCA ports on TV - cable like this:
CablesToGo, Velocity 3.5mm Stereo Male to Dual RCA Male Y-Cable, 3m - Ebuyer
Then it depends what laptop you have you might need to press the Fn key and a F-Key to get it to output to the TV, what make/model laptop is it maybe someone can tell you what key.
It's very simple to do :thumbsup:
