Laptop to Tosh problem
Discussion in 'General TV Discussions Forum' started by stewbold, Feb 18, 2005.
  1. stewbold
    stewbold
    Jan 30, 2005
    168
    Buckley, Flintshire
    +11
    I am trying to connect my laptop to the Toshiba 46" DLP. I have a Fujitsu Siemens Amilo Laptop with an ATI Radeon 9600 graphics card. Plenty of RAM and processor speed. I am connecting using a VGA cable. Whatever I do, all I seem to get on the TVs display is the desktop picture in the middle of the screen and nothing else. The TV says "XGA". I have tried to play around with the display settings to no avail (incl 1024X768) Don't get me wrong. The desktop picture looks lovely on the big screen but would like to play some DIVX stuff etc.
    Any ideas or is it time to invest in a new graphics card for the laptop?
    Many thanks
    Stewart
    PS. I have the same problem when trying to connect my PC's monitor so I am sure the problem is at the laptop end.
  2. stewbold
    stewbold
    Jan 30, 2005
    168
    Buckley, Flintshire
    +11
    Now sorted
    Stewart
  3. Les
    Les
    Jan 1, 2005
    103
    Livingston, Scotland
    Hi Stewbold
    I'd be interested to hear what you did. I have the Tosh 52" on order and have a Dell laptop with same graphics card that you have. What connection etc did you find worked OK?
  4. stewbold
    stewbold
    Jan 30, 2005
    168
    Buckley, Flintshire
    +11
    Hi Les
    I use a VGA lead from the laptop to the TV for the Pic and connect my laptop to an amp for the sound, though you can connect direct to the TV if you have the right lead.
    Here (I think is how I sorted out the problem (which was at the laptop end):
    Right click on the desktop and select properties to get the display properties box. Then select "settings". Make sure that you have "multiple monitors on ATI mobility radeon" selected under "display". Then select "advanced". This brings you onto the page of ATI options. Select "Displays". Then click on ""Monitor" (for some reason although it is connectd to a TV it doesnt recognise this-maybe would only work with a DVI connection?) Set max res at 1024X768 and refresh rate at 60hz. Click apply and then OK. Under the monitor tab there are buttons for "1" and "2". Select "1" (making the monitor the main display). Click apply and then OK. Yout TV should now be your laptops display where your laptop will now just display the background pic.
    You should also by the way before you do this, select PC on the Tosh's handset.
    Hope this helps
    Stewart
  5. Les
    Les
    Jan 1, 2005
    103
    Thanks stewbold - I will get a long vga lead ordered. Do you find the TV as a display good? From other threads I believe it should be OK.
  6. stewbold
    stewbold
    Jan 30, 2005
    168
    Buckley, Flintshire
    +11
    As a display for the laptop? yes very good.-though I am not using it for general PC stuff. Mainly been using it with the Divx player and some of the HI-Def DivX clips. These look absolutely stunning on the TV. Its alao quite handy for photo slide shows etc.
    Regards
    Stewart
  7. digitize
    digitize
    Stewbold, where did you get your Hi-Def DivX clips?
    Are they just clips or movies? Are there any hi-def divx movies available already?
  8. stewbold
    stewbold
    Jan 30, 2005
    168
    Buckley, Flintshire
    +11
