Laptop to HDTV Lead????
Iain Allan
Sorry this is probably a very simple one but can anyone point me in the right direction of a lead to connect my Packard Bell Easynote R4 Laptop to my Samsung LE26R41BD.
The tv is hdtv ready and I was hoping to get the most out of that!!
Thanks in advance.
Bl4ckGryph0n
It helps if you tell us what display connectors both devices have available.....
Laptop: DVI-I/D?, VGA, Component, s-Video, Composite - One or more probably...
Samsung: HDMI, DVI, VGA, Component, Scart RGB/s-Video/Composite? - One or more probably...
Iain Allan
Hope this info is enough
Laptop: S- Video Output
TV: HDMITM, PC input
Hope this info is enough, please mind my ignorance on this!!!
Thanks :clap:
Rambles
Your laptop must have a vga out? That would be much better than s-video, dvi/hdmi would be even better.
Bl4ckGryph0n
Yes surely the Laptop much have a VGA port. If so then use the VGA on laptop to PC-Input...
If not, but it does have a DVI. The first step is to find out what type of DVI, if it is digital get a DVI-HDMI cable, if not get a DVI-VGA cable...
Very last resort use a standard s-Video cable...
Trending threads
