Laptop to amp no picture please help
Discussion in 'Home Cinema Buying & Building' started by technique786, Feb 23, 2014.
  1. technique786
    technique786
    Dec 20, 2011
    311
    +8
    Hi All,
    I have a sony bravia tv and a epson tw9000 conected through a onkyo 509.
    My zotac htpc used to be connected to my amp and produced HD pictures on both the tv and the projector but it died and i have bought a Acer E1-571 laptop. This produces no picture on either the tv or the projector and both claim unsuported signal.
    I have tried changing resolutions but thats no good and i have checked frequency but at 60hz thats fine too. Has anyone found a solution to this problem, I am desperate as my entire setup is just going to waste without a means of playing video
    thanks for the help
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,724
    The Borders
    +3,513
    Are you connecting the Laptop direct as a test?
    Joe
  3. technique786
    technique786
    Dec 20, 2011
    311
    +8
    I had connected direct to make sure it worked that's why I was so confused. It turns out to set it up correctly I needed to set the displays to extend then change its settings manually and switch back to display hdmi. Thank you for the help.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,724
    The Borders
    +3,513
    Good you got it going - always good to post the 'fix'.
    Joe
