Laptop to 37pf9986 via DVI
Discussion in 'LCD & LED LCD TVs Forum' started by Tony B, Dec 11, 2004.
Tags:
  1. Tony B
    Tony B
    Oct 29, 2004
    551
    +21
    Well I have the physical connection sorted out, but regardless of the resolution I choose on the laptop I get the same message on the TV - "Picture format not available"
    What am I doing wrong?
  2. Alan D
    Alan D
    Check that your graphics card is set to 1024x768 at 60Hz. I'm guessing that the 60Hz bit is the most important.
  3. Tony B
    Tony B
    Oct 29, 2004
    551
    +21
    I tried all resolutions, which included 1024*768. I can only set 60hz anyway.
    Even tried rebooting the pc from cold...
    Is there a configuration within the TV set-up for this sort of thing?
  4. stevie_velvet
    stevie_velvet
    your trying the dvi - vga cable that come with it ? ~ have you confirmed you can output a external picture from your laptop ?
    try changing to a lower resolution and with that a higher refresh rate & ensure latest drivers are installed
    i'm looking at the same setup also for next year so am keen how you get on
    stevie velvet (ms.)
  5. Tony B
    Tony B
    Oct 29, 2004
    551
    +21
    I am using VGA>VGA>adaptor>DVI
    It is a Dell Inspiron laptop. I have used other Dells in this manner, outputing to projectors, although I have not tried it with this particular one I can think of no reason why it would be different.
    Make physical connection and then hit Fn+F8, which normally toggles between 1 display (internal), then the other (TV or projector) then both simultaneously.
    When I hit the Fn+F8 keys I get the message mentioned above on the TV screen, so something is getting through.
    I tried all available resolution options. I only have 60Hz refresh rate option available on the laptop. I wonder whether this the problem?
    Using Windows XP SP2, if that makes any difference.
  6. stevie_velvet
    stevie_velvet
    so long as the laptop is tested as output to another external screen, then i suggest borrowing someone's VGA-DVI interface are upping the refresh rate or horizontal scan rate
    have you checked both modes of the inspron, i.e. External + Internal, & External only ?
    ..a have look at other threads as they seem to get PC-DVI to work ok
    2 more things, for my own planned setup, can you post a pcture of the connectors, i can't find on anywhere on the internet
    lastly...how have you connected ta AV source to it ?
    thx
    stevie velvet (ms.)
  7. Yaka
    Yaka
    Dec 20, 2000
    1,740
    2
    63
    +130
    your best off using a VGA port if your telly has one, or the TV out (svhs) on the laptop.
    vga->DVI which your basicly doing works only some times without any headaches.
