laptop speaker system help
Discussion in 'Headphones, Earphones & Portable Music' started by diehard1985, May 16, 2005.
  1. diehard1985
    diehard1985
    May 16, 2005
    lo
    Im not sure if this is in the right forum (i hope it is). Im looking to upgrade the soundsystem on my laptop. I want to use it for listening to music, watching dvd's and playing games (primarily for the first two). I want a surround sound system (at least 5.1) that can handle dobly digital and dts stuff. However im not sure whether i should buy a new hifi system and hook it up to that or get an external soundcard with pc speakers (ive been loking at the pcmcia soundblaster extigy) what do you guys think? I got around £300ish to spend. Any advice would be great. cheers.
  2. HMHB
    HMHB
    Nov 11, 2001
    25,459
    Nottinghamshire
    +3,767
    What are the specifications of your current laptop ?
  3. diehard1985
    diehard1985
    May 16, 2005
    its a pentium 4m 2.4ghz
    640mb ram
    60 gig hard disk
    dvd/cdrw combo
    onboard audio
    nvidia geforce 4 440 go graphics
  4. HMHB
    HMHB
    Nov 11, 2001
    25,459
    Nottinghamshire
    +3,767
    To do DD and DTS you need a digital output of some kind on your computer, does it have one with the onbaord sound ?
  5. diehard1985
    diehard1985
    May 16, 2005
    no it doesn't - its a very basic integrated soundcard. all it has are the basic headphone input and one speaker input.
  6. HMHB
    HMHB
    Nov 11, 2001
    25,459
    Nottinghamshire
    +3,767
    You could probably start by looking for an offboard sound card then, creative and the other big boys do USB sound solutions for laptops.
  7. SBanga
    SBanga
    Mar 23, 2005
    2,011
    Leeds, Yorksha
    +267
    Buy a Logitech Z-5500. If my old Logitech Z-2200 2.1 system is anything to go by, these are certain to blow you away. They are also THX certified and more highly rated than similar offerings from Creative. Check with your neighbours first though!!!
  8. diehard1985
    diehard1985
    May 16, 2005
    cheers for that, ive heard mixed opinions about usb soundcards though - that the datastream isnt big enough to handle all of the modern effects and so it can only software emulate them - hence I was thinking a pcmcia soundcard would be better. I was looking at the creative extigy pcmcia one which looks good but apparently due to weird inputs it only really works properly with creative speakers - is that right? Any other suggestions?
