Laptop Sound Card
Discussion in 'Headphones, Earphones & Portable Music' started by Savan, May 6, 2005.
  1. Savan
    Savan
    I've got my laptop connected to my LCD screen, and have the audio connected to a home cinema system using an RCA jack with a stereo audio jack. The sound is pretty useless.
    I am considering getting an external USB sound card from someone like Creative, and instead of connecting the home cinema system, I'll use my desktop PC surround sound speaker package.
    :lease:
    Does anyone know if this will make a slight bit of difference?? Will the sound card provide much better sound compared to the inbuilt one?
    Any help is much appreciated.
    Sav
  2. Fencer02
    Fencer02
  3. Savan
    Savan
    Thanks Fencer
    The laptop I have has got a Soundblaster 3D compatible 16 bit chip built in. I guess what I'm asking is: when playing DivX's, I find I currently have poor sound. I've read that WinDVD gives you better sound than WMP, but I thought that it might just be down to the fact that the built in sound chip is poor.
    Do you think the Creative External USB kit will provide better sound than the built in chip? Like you, I have Altec Lansing THX speakers and sub for my desktop which I want to plug in.
    Sav
  4. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,258
    +64
    You could look at the Audiotrak Optoplay. It offers an optical output in a very small package, so it can hook right up to the receiver via optical. The optical socket also doubles as an analog line-out and a headphone socket.
