Laptop/screen help
Discussion in 'Desktop & Laptop Computers Forum' started by nick67, Mar 6, 2013.
  1. nick67
    nick67
    Dec 17, 2004
    2,374
    83
    East Sussex
    +282
    Yesterday I received a Sony SVT1312Z1ES which is brilliant, I have now connected my Iiyama W2201W screen via vga and the blues appear purple on the LCD not the Sony.
    I messed around with the settings but cannot correct it.
    What am I doing wrong?
    Would connecting via HDMI to DVI-D resolve this?
    Thanks in advance
  2. nick67
    nick67
    Dec 17, 2004
    2,374
    83
    East Sussex
    +282
    I have now tried with a hdmi/DVi-D converter still the same problem
    The screen worked fine before with another pc
  3. trjp
    trjp
    Dec 12, 2006
    167
    +20
    Why are you connecting with VGA when your laptop appears (tho it's hard to be sure as there are many submodels in that range) to have HDMI?!
    Are you saying you get the same colour issues with both connection types - you've not made what you're doing enormously clear (we're not in the room with you - you need to explain everything you've tried - the cables you've used, the ports you have available etc. etc.)
    It's not ideal using adaptor/converter cables because it's easy to blame the cables - if you suspect the fault is with the laptop tho, you'll need to try it on another device (your TV perhaps?) to be sure...
    If it's purple there too - you have a wonky laptop - return it.
