Laptop Ram
Discussion in 'Computer Components' started by Sub_Low, Mar 25, 2003.
  1. Sub_Low
    Sub_Low
    Does anyone know a cheap supplier of laptop ram, specifically 512MB SD ram for an athlon XP 1.1GhZ?
    Any help on this would be great!
  2. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    http://www.crucial.com/uk/ offer a range of memory modules for laptops. You'll need to find out what type of module you need - it should be clear from the bundled documentation. If it's a SODIMM (as is most common) then upgrading should be fairly easy provided your laptop has room for another module.
    MuFu.
  3. Der_Pobman
    Der_Pobman
    If you dont care for the brand you can pick up cheap laptop ram from Ebuyer.com ... if you want a known brand then Crucial is pretty good, costs a little more sometimes though.
    I got 256mb PC133 Sodimm for my Dell from Ebuyer for a little under £30 a few months back, crucial brand was about £5 more at the time.
    Pobman
  4. alextgreen
    alextgreen
    Apr 17, 2001
    545
    London
    +5
    Maplins are quite good if you have a store locally.
