Laptop PVR
Discussion in 'Desktop & Laptop Computers Forum' started by steve_taylor_, Mar 18, 2005.
  1. steve_taylor_
    steve_taylor_
    Has anyone attempted to use a laptop with a USB hauupage PVR ? Apart form the disk size restrictions can anyone think of a reasont his shouldn't work ?
  2. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    The svideo outputs on laptops aren`t usually up to much (usually noisy and a bit soft), that`s one thing to consider
  3. steve_taylor_
    steve_taylor_
    Thanks Chris,
    I would want to record from my sky box. So I would presume that there is a coax into the USB PVR and then an s-video connection from the laptop back to the TV ? ( apologies for the stupid questions......)
  4. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    svideo from sky would be better if you can, and the same from the laptop to the tv.
