buddyspudface
Established Member
can anyone shed any light on my problem i have.
i have a acer 1692wlmi
problem i have is after i turn it on it does the system check and sometimes goes past this and i get to try to reinstall software. but most of the time what i get is a conataminated screen on start up with lines flashing all over the text and i locks out with the screen full of garbadge.
i first thought the memory was at fault as i have 2 banks of 512 in it and when this first started to do it i took a bank out and it fixed it for a couple of weeks. but now i have just bought 2 more memory banks ( 1 meg each )and i still have the same problem. so im £50 light in the wallet and still have a buggerd laptop
laptop was running XP, what i was trying todo was a startup disk so i can have the DOS prompt on screen so i can try a BIOS update. but typical vista homebase refuses to do one and now laptop wont even turn its screen on..does anyone have a shovel handy.....
