P
pompeyexile
Sorry this is so long but I want to give as much information as possible.
Last year I spent weeks burning all my 1300+ CD's onto i-Tunes because I have a Sonos system. The i-Tunes sits on a 2TB external hard drive, the hard drive is connected via USB to my TP link Wireless router and the router is connected via a USB to my old tower HP XP windows computer which has 2 cd drives. Unfortunately that computer is on its last legs and the CD burners very temperamental sometimes working and sometimes not and when they do they are very slow and therefore any new CD's I get I'm having more difficulty in burning.
So I thought if I loaded i-tunes onto my laptop and pointed it at the wireless router where the hard drive volume for i-Tunes is showing I could lay the old computer to rest.
However, when I loaded i-Tunes and pointed it at the same i-Tunes media location as the Sonos all I got was a version of my library that was over 6 months old and had all sorts missing. The i-Tunes on the old computer has the very latest with all album covers and if I do add another CD it shows it and when I update my Sonos music library it sees it too.
I tried to set up a home network thinking this would solve it but I'm as computer literate as a native of an Amazonian lost tribe and got into all sorts of bother. Because my old computer runs on Windows XP and that is no longer supported I used the free tool Windows supplied for transferring everything from that computer on to my laptop thinking that perhaps it would transfer the i-Tunes too and then wiped the old machine ready for the tip. Not a sausage! My laptop still didn't see the up to date library. So in my frustration I (now I know this seems drastic) took my laptop back to factory settings, I then loaded i-Tunes and still nothing.
I then thought what if I connect the wireless router directly to my laptop like it is with my old computer, so I took the laptop up stairs unplugged the wireless router from my old computer and....still not getting the latest library. I then plugged the router back into the old computer and went on-line and re-loaded i-Tunes on to it. Without me telling it where to look it immediately picked up the current library from the external hard drive. It just so happened that I had my laptop on with the now empty iTunes on it and I noticed in the 'Music' drop down 'Administrator's Library' so I clicked it and whoosh! my latest updated with all artwork library appeared just as it was on my old computer and on my Sonos.
Result!......Or so I thought. With a self satisfied grin as big as the Cheshire Cats from Alice I thought 'now I can get rid of the old computer' and proceeded to turn off the i-Tunes on it. As soon as I did though the i-Tunes contents on my laptop disappeared and of course the 'Administrator's Library' option in the Music drop down disappeared too. When I turned the i-Tunes on the old computer back on the whole library re-populated my i-Tunes on my laptop.
So, although I can at least see the most up to date i-Tunes library on my laptop I still can't get rid of my old computer which when it really does give up the ghost means I'm stuck.
My present settings are as follows:
Old Computer
i-Tunes media folder location - \tplinklogin.net\volume1
Laptop
C:\Users\Paul\Music\iTunes\iTunes Media
When I plugged the external hard drive into my wireless router it gave me the option under
storage sharing to save what was on it to a FTP server, or a Media server which I did and called it Volume1. When you then had to load the information from the external hard drive it showed 70
pages the first being so many artists on i-Tunes in alphabetical order A,B C and page two might
start at D and so on. What you could not do was pick all the pages.
This seemed irrelevant because as I said both the old computer and the Sonos picks up the whole
current library using the same link.
My network on my laptop is set up as my own (Pompeyexile) and is at present public and that is the name for my wireless network on my TP Link router.
Sorry it was such a long read and if you're still awake your advice would be much appreciated.
In short all I want is to be able to throw away my old computer and still be able to burn CD's to
i-Tunes currently stored on my 2TB external hard drive that is connected to my wireless router and see the latest library.
Old Computer
Laptop
