laptop modem problem
Discussion in 'Desktop & Laptop Computers Forum' started by gooner#14, Sep 23, 2005.
  1. gooner#14
    gooner#14
    Jul 18, 2005
    481
    got a sony vaio and im trying to connect it to the internet via a dial up service thru ntl,
    ive got a "zonet zfm5600" 56 kps fax/modem pc card is this all i need to connect to the internet???
    because when i try to connect it says no connection to the internet can be found!!!!!!!!
    any help would be gr8 ta
  2. Puffer
    Puffer
    Mar 20, 2005
    109
    16
    Need more information on what you have tried to connect to the Internet
    such as have you set up the dial up connection for ntlworld .
  3. gooner#14
    gooner#14
    Jul 18, 2005
    481
    ???? all ive done is connect a telefone line to the laptop and put in the ntl dial up disc installer but when it tries to go online it just says that its unable to connect to the internet"!!!!!!!
  4. Puffer
    Puffer
    Mar 20, 2005
    109
    16
    When you right click the Internet explorer icon, click properties
    then click on connections,is ntlworld listed there .
  5. gooner#14
    gooner#14
    Jul 18, 2005
    481
    nope!!
  6. gooner#14
    gooner#14
    Jul 18, 2005
    481
    also when dialing up the card makes a whooshing noise instead of a tone ( like a speccy loading)
  7. Puffer
    Puffer
    Mar 20, 2005
    109
    16
    Oh thought you got it sorted gooner#14, the card probably making a whooshing
    noise because your setting for ntlworld isn't properly configured.
    If you want PM me and we will try an get it sorted for you.
