We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Laptop memery upgrade
Discussion in 'Desktop & Laptop Computers Forum' started by fire boy, Oct 18, 2005.
  1. fire boy
    fire boy
    Dec 14, 2004
    285
    London
    +7
    I confess to not knowing a great deal about pooters but after reading through the sticky on water cooling I must be slightly above the ranking of moron :smashin:
    I have a Tosh laptop about a year old from pc world and I want to upgrade the RAM from 256Mb
    Is there a max size I can replace in with?
    If it make a difference the model number is- PSA40E-0E4N1-EN
    and it uses a celaron prosseser 2.80Ghz and has a 64Mb graphics card
    Also will this let me run some of the newer pc games like Lotr battle for middle earth?
    Regards Brian
  2. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    The PSA40E-0E4N1-EN is actually a Satellite A40 according to a quick Google search which means that it requires PC2100 DDR Ram :) The A40 has 2 memory slots so you can purchase one more stick giving you the option of going for an extra 128mb, 256mv, 512mb, or 1gb.
    Crucial is a good bet if you want to be sure that you purchase the correct stuff - you can enter the make and model of your laptop and get a recommendation that is guaranteed to work. The service is top notch as well :smashin:
  3. fire boy
    fire boy
    Dec 14, 2004
    285
    London
    +7
    Thankyou for helpful reply. :thumbsup:
    If I go too high can I damage the pc (I was thinking of adding 512Mb)
  4. kelvin
    kelvin
    Apr 22, 2002
    1,598
    +45
    It's pretty difficult to do any damage - at worst you'll find that the laptop won't boot but 512mb won't be a problem. Over 1gb you sometimes run into problems on older machines but given that yours is relatively new I can't imagine you'll have any trouble.
    Go with the Crucial stuff and you can always return it if it doesn't function correctly :)
  5. The Dude
    The Dude
    May 21, 2004
    6,772
    Beverley, East Yorkshire
    +3,242
    no worries there.. just use the crucial memory selector tool already mentioned, and go for the biggest module it offers for your machine, if you can afford it.. :devil:
    An extra 512 would go very well in a machine like yours.. :)
  6. Arif
    Arif
    Feb 13, 2004
    94
    Northampton
    For what it's worth - and if you're still going even to check back here...
    But I had precisely the same issue on my Toshiba Satellite - which only came with 128 Mb of RAM!
    These guys did for me exactly as they've done for you - and I went down the Crucial route - and it was awesomely simple, from start to finish.
    Even the replacing I did myself because these guys and girls here assured me it was pretty simple - and it was!
    Plus the chip itself comes with instructions from Crucial - and their website is excellent.
    A RAM-upgrade will absolutely transform your system.
    And while I'm at it - "Thanks all!" - your help very much appreciated. The alternative would've been to pay someone a good amount of money.
    Lifesavers, you lot!
