Laptop HP 14S any good?
shoemaker666
Need a new laptop my current one is on its last legs about 10 years old now its spec is 14inch 4gb ram 256gb harddrive and just got an old pentium in it. so was thinking of the HP 14S should be way faster 8Gb ram 256SSD ryzen 4500U. my old one still does what i need it to internet browsing some video content and old games so this new one should be more than adequate
just a few questions
  • Whats windows 10 S ?
  • no Ethernet port is there some kind of usb adaptor i could buy to plug in if needed ?
  • internal battery can these be replaced when they get knackered ?
HP 14S Laptop, AMD Ryzen 5 Processor, 8GB RAM, 256GB SSD, 14" Full HD, Silver at John Lewis & Partners
Atomic77
Established Member
I am not sure what S means either. I'm not 100 percent sure but I think laptop batteries are replaceable. they are rechargeable but probably won't last forever.
outoftheknow
Kapkirk
Think I would look at a different laptop if I were you, the "S" seems to denote that it will only run apps downloaded from the microsoft store, no removable bat and no ethernet port -no thanks!
shoemaker666
most laptops dont come with a removable battery now unfortunately. and Ethernet port seemed to be on some latops last year but this years models seem to have done away with them
outoftheknow
ah cool so can just do a free upgrade to windows 10 home
That’s how it looks :) removable batteries I don’t see as a big deal nowadays and no ethernet port is probably the way of the future. I would say you can still get those on business models but for personal use laptops I don’t think they matter. How many times do you take a laptop out of the house with an Ethernet cable in your pocket and look for sockets in cafes and other people houses?
Also if it has USB C you will also most certainly be able to buy the modern version of a docking station/power supply. Those still have an ethernet socket and decent sockets for screens so use that at home if you want it to be your main PC at home. Unplug one USB C and off you go.
shoemaker666
so I could buy an adaptery i could plug in usb c that would provide an ethernet port?
outoftheknow
Indeed. Dell do a USB 3.0 version that doesn’t charge the laptop
And a USB C version that also charges the laptop
We use the latter (older version) at work now instead of the old fashioned docking stations. They work perfectly and mean one cable to keep a workstation at home (in your case) using the laptop as the PC.
Atomic77
Established Member
My Laptop the HP 17 ca1065cl has a port on it. I just bought it in July of this year.
🎬 The Creator & Reptile, Guardians 3, The Others & Cutthroat Island 4K & Best/Worst Renny Harlin
Back
