For Sale Laptop DRR4 RAM, water cooling and router
Discussion in 'Archived Classifieds' started by s9abdul, Apr 26, 2018.
  1. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    Getting rid of a bit of clutter in the house, bit of upgrading/ downgrading
    8GB Single Stick SODIMM RAM DDR4 2400mhz - £45
    2x2GB SODIMM RAM DDR3 - £5
    Linksys WRTAC1900ACS has been reverted to stock firmware as i had it on DD WRT for VPN use (i do recommend a custom firmware for this as this is what it was built for) - £70
    1x EK SUPREMACY EVO CPU BLOCK copper block with AM4 Ryzen mounting bracket £30 - NOW £20
    1x EK-XTOP SPC-60 PWM - PLEXI (INCL. PUMP) (PWM controlled clear so that you can see your liquid. This has the mounting grommets on it but i can't find the screws. It only needs 4 will update the thread if i find them or some that might fit) £30 - NOW £20
    2x Monsoon FREE CENTER HARDLINE Fittings 3/8 X 1/2 (13MM) 6 PACK - MATTE BLACK a six pack will comes with the clear glue to attach the lock collar to the tubing
    I have 2 6 packs of these, and three more separate ones. One is unused and still has the lock collar. Each 6 pack comes with a tightening wrench these will require lock collars as the ones that come with them have been used and they are not reusable. These are not expensive only £4 for a 6 pack.
    Total 15 regular fittings £30 for all 15 - NOW £15
    1x Barrow Cylinder T-Virus Black POM Cap Red Spiral Suspension Reservoir 205mm £15 lower price due to scratch NOW £8 (This has a UV light inside also this does have scratch across where the mounting bracket sits, luckily this cant be seen once the bracket is mounted)
    MMRS PREMIUM G 1/4 PLUG - MATTE BLACK (this will be free with reservoir)
    6 x Silverstone Fan Grills packaged and unopened (bought for a desk PC build but i didn't get permission from the boss so it was scrapped :() £25 for all - NOW £10
    Corsair DDR4 2x8GB 3200mhz RAM in RED - SOLD TO acave
    Its this one Corsair 16GB DDR4 Red Vengeance LPX 3200MHz Memory Kit for Skylake
    If using Ryzen you can definitely get this RAM running at 2933 mhz minimum, Intel you just run the XMP profile for 3200 mhz or it can overclock 3466 mhz on some boards. I had this on 3200 mhz on Skylake and 2933 mhz on Ryzen 1st gen.
    2x G2 SLIM RADIATOR 16 FPI - 240MM (copper radiator) SOLD TO JACKs4B
    Radiators have removable dust filters and also removable rubber to absorb the vibration from the fans (i had an 1700 over clocked to 4.0GHz and and overclocked 1080ti both in the loop with these, SP120s set at 900RPM kept them both cool whilst silent.
    3 matte black monsoon 90 degree fittings SOLD TO Viberious
    4x Corsair CO-9050006-WW Air Series SP120 Quiet Edition 120mm Low Noise High Pressure Fan (These are the PWM versions) 1 DUAL PACK SOLD TO vetch1
    1 DUAL PACK SOLD TO Boniek
    PETG TUBING 13/10MM (ID 3/8 OD 1/2 90CM) - CLEAR (i have one full 90cm and 65cm none these have been used
    2.5 inch hard drives:
    1TB Toshiba MQ01ABD100 (this is a 9mm drive so should fit into a PS4 and most laptops) - SOLD TO dirtyHarry108
    500GB TOSHIBA MQ01ABF050 (this is a 7mm drive so should fit in everything) - SOLD TO dirtyHarry108
    Drives have been wiped and health status is on post 23 all in working order
    For Sale - Hard drives, x370 mobo, water cooling and fans
    Everything is in brand new condition apart from the radiator and reservoir. All come with boxes. Water cooling kit has been cleaned out with distilled water, however it has been sat in a box for months, so make sure you flush out any dust on the inside as i have just cleaned the outside before boxing them up again. Will be some more bits and bobs as i'm still clearing out and hopefully i can find some invoices.
    Update i have found the invoices for the pump, water block, fittings and radiator. All purchased from Overlockers around May 2017. Reservoir was purchased from ebay, so i would expect any warranty with this, but then again it's just a tank.
    I'm in Sheffield if anyone would like to collect.
    View attachment 1021910 View attachment 1021911
  2. xMK9x
    xMK9x
    Aug 24, 2009
    571
    NW
    +33
    Interested in the N900, do you have an estimate for postage?
    Ta
  3. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    £4 if you don't mind slow post?
  4. xMK9x
    xMK9x
    Aug 24, 2009
    571
    NW
    +33
    Yep that will be fine, PM me your paypal
  5. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    Im new here, according to the FAQs being a novice member means i can't start conversations. Can you try to PM me instead? Thanks
  6. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    Are you still wanting this?
  7. Krooner
    Krooner
    Jun 14, 2007
    4,745
    +511
    I'll take it buddy if it's still available.
  8. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    Sure PM me and I'll get it sent out Monday.
  9. Switch625
    Switch625
    Jan 15, 2005
    1,493
    +183
    Can I have the flat ethernet cables? Will drop you a PM for details.
  10. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    All of them? Yes PM me I'm about to go to the post office, so I can get them sent out today.
  11. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    Queue was too long at the post office, would have been there a while, didn't have much time. I'm going to send this out via myhermes instead.
  12. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    Did you receive this okay?
  13. Krooner
    Krooner
    Jun 14, 2007
    4,745
    +511
    It's arrived mate yes, I've just not had a chance to set it up.
  14. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    Great, i doubt you'll have any problems setting it up.
  15. jouster
    jouster
    Feb 16, 2005
    15,678
    Abberton, Colchester, Essex
    +7,451
    as per your post on a wanted thread, have you got some more details on the 12TB hard drive I see its sealed but do you have a serial number and also a receipt for warranty purposes??
  16. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    Will update the thread hopefully by the end of the day, been a busy week.
  17. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
  18. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    Have updated thread now the picture should have the S/N on it
    More Pictures
    https://drive.google.com/open?id=1II3iZOGzOiKH0Zs_O4aMgwTTc6ca5dsH
    [​IMG]
  19. Terminator27
    Terminator27
    Jan 6, 2016
    961
    28
    Pontefract
    +94
    What was the reason for the rma on the ironwolf, I've read a few reviews on amazon and they seem a bit unreliable.
  20. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    I dropped it and missaligned the read/write heads.
  21. Terminator27
    Terminator27
    Jan 6, 2016
    961
    28
    Pontefract
    +94
    Oh ok, would you do £220 on the 12tb, I can collect, I'm only in Pontefract.
  22. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    Would you do £230?
  23. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
  24. dirtyHarry108
    dirtyHarry108
    Nov 25, 2006
    2,074
    Brum
    +83
    Any warranty left on the 2.5 2tb drive? What brand is it?
    Health ok?
    Thanks.
  25. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    No warranty i'm afraid as seagates website states to contact the place i bought it from and i dont have the invoice. Health is fine drive is a seagate ST20000LM007. Will upload a proper health check once its complete.
  26. Boniek
    Boniek
    Jan 30, 2011
    73
    9
    Leuchars
    +6
    Hi, how much for 2 fans posted?
  27. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    £12 okay?
  28. dirtyHarry108
    dirtyHarry108
    Nov 25, 2006
    2,074
    Brum
    +83
    Googling doesn't return much results.
    Any chance of a pic? Is it sata 3?
    Finally, would you post first due to low feedback?
  29. s9abdul
    s9abdul
    Apr 26, 2018
    372
    28
    Sheffield
    +44
    Picture: 20180528_190124.jpg
    Yes it is sata 3 and yes i would post first if you provide me with some form ID as i'm trying to be a bit more cautious as one member on this site has already taken my money and not sent me my item after 2 weeks.
  30. brunation
    brunation
    Jul 26, 2004
    1,160
    63
    Glasgow
    +105
    Try ST2000LM007
