Victor Meldrew
My name is Paul. I Live In The United Kingdom. I Am Looking For Advice On A New Laptop & Would Appreciate Any Advice From The Members On This Forum.
I Have Researched What I Require However My Ambition May Out-Weigh My Budget!
I Will Use The Laptop for Web Design, Mainly Photoshop CS5 Extended (Repousse & 3D), Adobe Flash CS5. Also Some Video Editing But Nothing Major In That Department.
I Am An Absolute No-Goer On CPU, HDD, SSD etc etc. My Head Is Spinning Reading About CPU's, Hard Drives, Graphics Cards etc & I Commend Those Who Know About These Things, So Much Choice And Price Range That Someone Like Me Is Lost!
I Have Read Advice After Advice On The Internet But Whatever One Site Suggests Another Site Contradicts!
I Have Done My Research And Below Is What I Have Come Up With That I THINK Will Suit My Needs For The Next Few Years, But Will It Suit My Budget?
What is your budget? £500-£600 could stretch to £700 At A Push If Absolutely Necessary.
What size laptop do you want? 16"
Do you have resolution requirements? 1280x800
Do you want a matte or glossy (reflective) screen? Matte If Cheaper (Would Rather Spend On Memory/Speed. But Glossy Preferred.)
What will you be using the laptop for? Web Design & Video Editing.
If you will be gaming, what games do you need to play? N/A
How long does the battery need to last? 6hrs Would Be Ideal.
Does it need to be portable? Would Be Great Portable But Can Handle Either....Down To Price!
Do you require Blu-Ray? No
Do you require HDMI output? Yes
Do you have a preferred brand? Not Knowing One Brand Performance From Another I Have No Preferences & Would Willingly Consider Anything Recommended Here.
Are there brands you would prefer to avoid? Not Knowing One Brand Performance From Another I Have No Preferences & Would Willingly Consider Anything Recommended Here.
Would you be happy with a refurbished laptop? Not Really Would Worry About Long Term Reliability. But If I Am Wrong Thinking Like That And It Is Worth While I Would Consider.
Any other details you feel necessary:
Colour: Black but not fussy as long as not pink!
Webcam: No
Good quality speakers: Would Be Nice But Not Important.... Again Would Rather Spend Money On Memory/Speed.
Here's The Mind Boggling Stuff (for me anyway)............
General Spec:
CPU: Intel i7 3GHZ Or More
RAM: Minimum 3GB But Would Like More If Possible.
HDD space: Minimum 200GB But Would Like More If Possible.
SSD: Intel x25-m 80GB
Operating System: Windows 7 Professional 64bit.
Wireless: Yes
SD/MS Pro MMC XD Slot Required
Anything else you can think of:
Using A Compaq At The Moment (Which The Wife Is Waiting To Inherit!) The Fingure Pad Buttons Make A Loud 'Clicking' Noise When Pressed So Would Like Buttons That Are Not So Noisey....Petty I Know But It Is Irritating After A Time!
Please forgive my ignorance if any of the above is absured to someone in the know. I want to buy what is best for my budget to do the job I want. I do not want to walk into computer shops to be baffled into buying the wrong thing by a salesmen or women who want to make a sale.
Best Regards
Paul.
Webcam: No
General Spec:
Wireless: Yes
Best Regards
Paul.
