Laptop advice needed for editing AVCHD
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Erkybaby, Feb 5, 2009.
  1. Erkybaby
    Erkybaby
    Nov 27, 2006
    45
    Waltham Cross
    +6
    Hi All
    I'm looking to purchase a new laptop for editing footage from my Sony TG3.
    I also need to use it to edit pictures from my Nikon D90.
    I have been looking at the new 17" Macbook Pro as a fair few people have recommended I go for a Mac. I have a budget of £2000.
    Do you think the Macbook Pro will do the job or should I be looking for a windows based laptop like a Rock, Alienware or Dell XPS?
    Any advice would be great and much appreciated.
    :thumbsup:
  2. RenaultSport
    RenaultSport
    Feb 1, 2006
    1,341
    Saint Albans
    +175
    Both would do as you have the likes of Final Cut Pro on the mac and Sony Vegas/Adobe Premier etc on the pc all of which will handle the AVCHD format the sony camera uses.
  3. tony79
    tony79
    Jan 6, 2005
    1,172
    +88
    Macbook Pros will be more than capable of editing avchd (imported under a pro res codec in final cut). I'm able to edit with no problems on my imac (roughly similarly specced). Question is, whether you really need the extra 2 inch of screen or not as the new 17"'ers have none removable batteries which may or may not influence your decision. I've not played with a really powerful pc laptop with avchd so cant comment on their performance. But I must say, since I got the mac my old pc has been gathering dust and I will not be going back to a windows based machine again.
  4. A n d r e w
    A n d r e w
    Jun 25, 2008
    2,039
    Sydney
    +242
    Any Intel Mac will do the job. I edit HD video on a 2 GHz 2Gb Mac mini.
    There is no "native" AVCHD editing on Apple software (iMovie, Final Cut Express, Final Cut Pro / Studio). Apple's editing applications "transcode" AVCHD using the Apple Intermediate Codec (AIC: only Final Cut Pro uses the Pro Res codec) which makes editing HD much less processor-intensive than editing native AVCHD on a PC.
    For a list of supported camcorders for iMovie, for example, check here: iMovie '09: Camcorder Support (actually, it lists the TG1, which is the US model number for the same camcorder).
    Andrew.
  5. Erkybaby
    Erkybaby
    Nov 27, 2006
    45
    Waltham Cross
    +6
    Thanks guys, I will go for the 17" Mac Book Pro and get Final Cut Express :smashin:
