Landscape lens, or stick with kit lens?
Discussion in 'Photography Forums' started by Darthchaffinch, Jan 5, 2012.
  1. Darthchaffinch
    Darthchaffinch
    Nov 23, 2007
    1,770
    Gothenburg, Sweden
    +465
    Hi!
    Really want to focus on landscape photography now I'm somewhere worth snapping- and think the sigma 10-20 would be a good choice (esp. on my limited budget), but have just been reading some old threads saying 10mm can be too wide and that 18mm is actually ok.
    Should I stick with the kit lens?!?
    Thanks!
  2. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    It can be if objects are close to you, but not for an uncluttered landscape. The point is that if you don't buy the lens then you'll never have the option.
  3. shotokan101
    shotokan101
    Jun 16, 2009
    74,622
    4
    Glasgow
    +24,885
    No - 17 or 18mm is definitely not wide enough for landscapes - only really appreciated this after I got one - Sigma 10-20 is a great lens for landscapes :smashin:
    Jim
  4. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    Christchurch , New Zealand
    +748
    I shoot most of my current landscapes with my 17-55. if 17 isnt wide enough I shoot a pano and stitch.
    There are a handful of exceptions, when I want close foreground and lots of DOF or shoot a wide seascape or something.
    Then I reach for my 10-20. Which is (IMO) too wide more often than not for an average landscape.
    It certainly has its uses, and uses outside of landscape shots too, but given the choice I would upgrade my kit lens to a 17-55f2.8 or similar.
  5. =adrian=
    =adrian=
    Jul 4, 2007
    16,609
    The Internet
    +7,148
    17-40 is very good for landscapes on FF.
  6. Darthchaffinch
    Darthchaffinch
    Nov 23, 2007
    1,770
    Gothenburg, Sweden
    +465
    Thanks chaps, I have a D90 so think will get the sigma! :)
  7. shotokan101
    shotokan101
    Jun 16, 2009
    74,622
    4
    Glasgow
    +24,885
    And of course the 10-20 gives approx. equiv. of 15-30 FOV on a crop sensor :)
    Jim
  8. Strobe
    Strobe
    Aug 29, 2003
    2,875
    Southampton
    +168
    Most of my landscapes are between 12-16mm on a crop sensor (having said that my UWA only goes out to 12mm but I haven't felt the need to go wider). The Sigma 10-20mm is known for sample variations so make sure you buy from a reputable supplier in case you get a dodgey one. Others to consider are the Tokina 11-16 F.2.8, the Tokina 12-24 F4 and the Nikon 10-24.
  9. Raymond Lin
    Raymond Lin
    Dec 23, 2011
    3
    There's no such a thing as "landscape lens". You can take wonderful landscapes at 70mm if you can compose for the right shot. There are however more traditional focal length which landscapes photography is associated with, personally I find the 16-35 is a bit too wide and you end up with distortion on the corners when it is at the wide end, around 20mm is a nice sweet spot.
    *FF numbers.
    /pendant
    I also think the kit lens is perfectly fine for this purpose. You are outside, do not need to shallow aperture for lack of light, often stops down a bit so sharpness isn't the greatest of requirements. Put it on a tripod and worry about composition before your kit. What a better lens can bring to the table is the nicer contrast and sharpness, and unless you really want that focal length.
  10. wongataa
    wongataa
    Jan 11, 2009
    1,541
    83
    Birmingham
    +498
    I like taking landscapes with lenses with focal lengths of 70mm and longer. You don't necessarily need a wide angle for landscapes.
  11. asaspasas6
    asaspasas6
    Nov 20, 2010
    310
    Sheffield
    +22
    did you mean Tokina 11-16mm f/2.8 & Tokina 12-24mm f/4 :thumbsup:
  12. asaspasas6
    asaspasas6
    Nov 20, 2010
    310
    Sheffield
    +22
    i love my tokina 11-16mm f/2.8 . build quality is superb. sharp even wide open.
    this taken at 11mm:
    [​IMG]
    centre by Andrius LTU, on Flickr
  13. Strobe
    Strobe
    Aug 29, 2003
    2,875
    Southampton
    +168
    Yes! Corrected.
  14. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    +748
    Hmm today was the first time I can remember ever wanting wider than 10mm...
  15. shotokan101
    shotokan101
    Jun 16, 2009
    74,622
    4
    Glasgow
    +24,885
    Sorry Rob but - PMSL :devil:
  16. blasted
    blasted
    May 26, 2004
    1,189
    63
    +132
    You can shoot a landscape at almost any focal length, its what's in it, not how wide it is. I have a 10-22 and its very difficult to get good compositions at 10mm, there's so much space. I would go with a 17-55 2.8, more than enough and a great fast lens for other things, much better than the kit offerings.
  17. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    +748
  18. asaspasas6
    asaspasas6
    Nov 20, 2010
    310
    Sheffield
    +22
    beautiful pictures , RobDickinson. WoW
  19. John7
    John7
    Aug 6, 2004
    2,536
    +761
    Pure class
  20. RajP
    RajP
    Feb 5, 2005
    6,030
    Northwood
    +2,071
    +2...
  21. sleekyG
    sleekyG
    Apr 30, 2009
    817
    43
    +143
    +3 :smashin::smashin::smashin:
    That shows that 17-55mm is indeed a good lens for landscape RobDickinson! :) Fantastic photos!
  22. tonyblade
    tonyblade
    Dec 2, 2007
    221
    +12
    Beautiful pictures bud! Truly beautiful.
  23. sneeks
    sneeks
    Jan 9, 2007
    4,233
    Glasgow
    +623
    Gorgeous photos.
  24. Darthchaffinch
    Darthchaffinch
    Nov 23, 2007
    1,770
    Gothenburg, Sweden
    +465
    +4!
    If I can get good enough in my lifetime to get shots like that I'll be happy. :)
  25. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    +748
    Thanks everyone, daft thing is those shots could have been taken with the kit lens just as well I think.
  26. marchand
    marchand
    Jan 18, 2007
    255
    28
    Wimbledon
    +36
  27. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    Ha I saw that today as well. The stupid thing is I did think it looked cooler with the red stripe....
  28. =adrian=
    =adrian=
    Jul 4, 2007
    16,609
    The Internet
    +7,148
  29. shotokan101
    shotokan101
    Jun 16, 2009
    74,622
    4
    Glasgow
    +24,885
    ...should've just sprayed the whole thing white...
  30. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    Standard zooms and primes are black with a red ring. Telephoto zooms, superzooms and primes are white with a red ring.
    Get back to your mouldy minoltas!
