Lamplife Tips
Discussion in 'General TV Discussions Forum' started by himpressive, Dec 20, 2004.
  1. himpressive
    himpressive
    Sep 28, 2004
    82
    11
    Hemel Hempstead, Hertfordshire
    +7
    I just had my sony KF42SX300 LCD rearpro tv replaced after the lamp went on my original unit :thumbsdow
    1. Are there any tips on what I might do to make the most of the lamp life (apart from leaving the TV permanently OFF :rotfl: )?
    2. Anything I should avoid?
    Thanks :rolleyes:
  2. Laurel&Hardy
    Laurel&Hardy
    Two things...
    1. Don't move the set while it's on or for at least 30 minutes after you switch off. Movement while the lamp is hot will knock a good portion of life out of it.
    2. make sure it's able to ventilate sufficiently to keep the lamp reasonably cool - they do run extremely hot. Again this will shorten the life of the lamp if it runs too hot.
