Question Lamp life
TJDK
I have just looked in the menu at the lamp life on projector and it says 155hrs - does that mean it has used that much or that is the amount left to use?
kbfern
Usually it signifies lamp hours used but that could depend on the pj.Most pj's have 2000hrs as a min and up to 5000 and even more depending on the make model. Lamps of course can fail at anytime though and this can vary depending on type of use.
TJDK
Thank you. This is for the Hitachi Illumina - I believe you kindly answered another query on it earlier.
kbfern
So in your case the bulb has been used for only 155hrs so should be good for another 1500 at least.
TJDK
Thank you, I knew it hadn't been used much as my husband was unwell for a few years before he died. I can be more confident to sell it now.
