Laminate/Carpet Sub Positioning
Discussion in 'Subwoofers' started by WBC, Jul 24, 2004.
  1. WBC
    WBC
    Guys,
    This may be a ridiculous question?!?!?!!!!
    I currently have laminate flooring, I'm moving back to carpet to try and take the brightness out of the sound. Could sub placement be different depending on the flooring????
    I am basically thinking of trying my sub somewhere else in the room before the carpet gets laid. If I like it, I'll run the cables before the carpet is put down but if its not a true test due to the sound changing after the carpet then I guess I won't bother!!!
    Stace :D
  2. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    The carpet will only have an effect on the brightness of the sound. Its really the dimensions of the room that most effect the acoustics. The only caveat to that would be the room being so acoustically bright that you cant hear which is the best place for the sub. Why dont you test it out by throwing rugs/blankets/towels on the floor to act as carpeting.
  3. WBC
    WBC
    Thats a great idea!!!
    The sub is currently behind a sofa (it has a fair amount of space around it), I do find it a bit boomy. I cannot put it up front (WAF) but could potentialy put it to the side of my other sofa???
    I just don't want to go out and buy new cables if its a waste of effort.
    Stace
