Lagged SKY via Hauppage PVR-150
P
Pickl3d
I recently set up my first 2005 XP Media Center, however I am getting a very strange problem in that the Display via the TV card is lagged by about 6 seconds and the audio is not quite synced right.
Anyone have any clues what might be going wrong here?
I have scart to s-vid (basic composite connection).
Sky->VCR(Scart-to-svideo)->TVCard
eg. I press a channel on the Sky remote and the menu pops up like 5-6 seconds later, ouch :confused:
The PC is well specced dual core / 2 gig ram DDR2 etc, so certainly no lack of power behind it :rotfl:
nigelbb
That's the way all TV works in Media Center. It is buffered to the hard disk before being displayed. This enables all the trcik play features like pause/rewind Live TV. You have a composite connection for your video, how is the audio connected? You should take L/R audio from the digibox & connect it to the socket on the TV tuner card.
naturbo2000
Also - stop using the sky remote!
All the channels are mapped to their existing numbers, so just use (/get) an MCE remote - there's still the lag when changing channels, but it's a *lot* more useable, and MCE can keep track of what channel you're actually watching. I guarantee you'll get some failed recordings otherwise...
alfaevans
Try setting your 'Search and Scan Banner' timeout to '0' Seconds.
Should help. My Channel switching takes just under 3 seconds.
To make things easier I always change channel by using the the EPG rather than surf up and down.
