Lacking bass with RME 9632 and Winamp?
Discussion in 'Desktop & Laptop Computers Forum' started by Cameron, Apr 18, 2004.
  1. Cameron
    Cameron
    hi there all, I have an issue which I'm hoping someone around here might know something about :)
    On one of my St Germain tracks - the sound has poor bass when played through my RME 9632 (via winamp). Its like the speaker has blown or something - I'm not sure quite how to describe, but it doesn't sound nice.
    When I play it through my Arcam or even on my usb headphones through Winamp it sounds like it should.
    Is there some type of setting I need to set on the RME or Winamp when using the RME (connected to my A75+)?
    thanks in advance
    CaM
  2. Madders
    Madders
    Jan 30, 2002
    2,308
    London
    +49
    Have you tried any other music player software to see if it has the same result? I would suggest Foobar2000 as it's free and easy to use - you can also get an ASIO plugin for it. At least this way you'll know whether it is a card or software issue.
    Cheers,
    Steve
  3. Cameron
    Cameron
    I have tried Media Center as well and its the same result. Through my USB headphones it sounds fine as well.
    CaM
  4. Cameron
    Cameron
    I now think that its my madnat connection.
    thanks for your time.
    CaM
