Lack of colour with R1 DVDs on a Sony TV
Discussion in 'General TV Discussions Forum' started by pcavelle, Nov 25, 2003.
  1. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    Hi -
    I have a friend with a recent vintage Sony TV, not sure which model. When he plays my R1 disks on his Sony DVD player, the colours are washed out, almost non existent.
    Is there a setting on the TV or player he should change? Does anyone know the answer to this?
    Many thanks
    Paul
  2. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    I'm guessing his TV does not support NTSC signals. Perhaps his DVD player can be configured to convert the signal to PAL.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,379
    Somewhere in South Yorkshire
    +5,766
    Or use a fully wiired SCART connection and set both DVD and TV to RGB.
  4. Bradford Blade
    Bradford Blade
    Nov 10, 2003
    2,735
    The Shire of York
    +728
    Hi Paul,,
    I had this problem when playing back R1's on an old Sony Widescreen (about 4 years ago now). I found this happened when using the RGB Scart. Switching to a pure S-Video input (usually located under the front flap of the set), not only the colours, but the picture was massively improved. Try this, it SHOULD work:smashin:
    Regards mate,
    LAGAVULIN
  5. fatbob
    fatbob
    May 22, 2003
    267
    19
    Hi Paul,
    Another possibility is that your friends dvd player is outputting an S-video signal to the tv via its' scart, but many Sony tv's come from the factory with the scarts ability to display NTSC through scart disabled, resulting in a distorted picture.
    One way to put this to the test is to get a normal s-video cable, and run it from the dvd player to the tv's front s-video input.
    If the picture is ok using this method, then you know the problem lies with the scart sockets.
    There are options in the service menu that allow you to enable NTSC through scart.
  6. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    Thanks for all of these suggestions - I have passed them on an hopefully one will work.
    regards
    Paul
  7. Bradford Blade
    Bradford Blade
    Nov 10, 2003
    2,735
    The Shire of York
    +728
    Please let us know if any do mate. I'm interested to know myself. Cheers :smashin:
    LAGAVULIN
