I have a problem with a Labgear HDMI splitter.
Input is from a Sky HD box. Two outputs, Toshiba LCD TV and Samsung LDs TV. When both TV's are on no. If the Toshiba is turned off I still get a a picture on the Samsung, but if I turn off the Samsung the picture is lost on the Toshiba. If I unplug the lead from the Samsung the picture on the Toshiba returns. It might be some sort of eco setting on the Samsung which is sending a signal to the splitter turning it off, but I've had no luck adjusting the settings. I'm tempted to de-solder the wire on pin 19, the "hot plug detect", as its the only one which remotely looks like it might be causing the problem.
Any ideas please?
Any ideas please?
