neilball
So, can a matrix be controlled from any of say four rooms?
Thanks for the help and suggestions BTW.
Most HDBT matrix support a range of control options, but is can be model dependent. This that allow IR control of the matrix source switching either use discrete codes for each room/source combination, others use the same basic source codes and rely on the receiver identifying from which room the signals are being sent from to switch the source to the right room. Many also support IP and/or web page control, others have RS232. Joe can confirm the Ovtava options, for other vendors you'd need to look at their specs to find out.
