L.F.E. ?
Discussion in 'AV Receivers & Amplifiers' started by ScottGreatorex, Jul 23, 2001.
  1. ScottGreatorex
    ScottGreatorex
    What does L.F.E. mean and what does is do if i change the db level?
  2. Guest
    Low Frequency Effects
    This will increase/decrease the "volume" (output) of the (digital) lfe channel (the 1 of 5/6.1) to the sub (if used) and/or the main left/right channels. this function (usually) has no effect on non-digital sources i.e T.V/Sky who's bass output is usually called "sub" etc.
    The lfe channel if you are not using a sub and redirecting to the main lefr/right channels is an entirely seperate entity to the bass imformation carried within the left/right channels although the two are present and mixed within the left/right channel.
