kylie dts no bass ???
Discussion in 'Movie Forum' started by k thompson, Nov 18, 2001.
  1. k thompson
    k thompson
    can anyone tell me why there is no base on my kylie dvd in dts and plenty in d/d 5.1??? this is the only title this happends on !
    the amp im useing is a paramount pictures hcs5300d .
    Im happy with the amp for now as im v.new to home cinema, i was just wondering why this should happen and has anyone come across this as well ???
  2. Guest
    Isn't it a 5.0 soundtrack ie no LFE channel? I seem to remember it says DTS 5.0 which would explain a lack of bass compared to a 5.1 track.. anyway the DTS version sounds a hell of a lot better than the DD one if you ask me
    Andy
  3. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,124
    3
    +8,059
    Check you have your speakers set to small, and your sub taking the bass for all channels.
    Only thing i can think off at this godly hour.
  4. k thompson
    k thompson
    thanks guys it does say dts 5.0 ,and it does sound good but just like a lil 'o' base lol................and the settings were ok thanks again saves me from takeing things back to the shop !
