$ky Broadband - Static or Dynamic IP?
CG121
With the launch of this new service I tried to ascertain the above information, but couldn't find an answer on their website..
Either I'm blind, didn't look long enough or they've decided to showcase the product and ignore the technical detail..
Although I strongly suspect dynamic IP's only, does anyone know if Static IP's are available on either the BT Wholesale or LLU services offered by $ky...?
Ta :)
beerhunter
I'm interested why you want a Static IP address? Or what Sky's offering has to do with BT Wholesale? I thought that most people would be end users. Just curious.
Tony Hoyle
It's probably dynamic. Plus if they follow the UKOnline model (easynet's last attempt at this) they'll block all the useful ports anyway.. so not an option if you want to run any kind of server.
For the 90% that don't it's perfectly fine... generally static IP is considered a premium service for tech-heads like me - most people don't use it.
CG121
Thanks for that. Looks like $ky won't be getting any further services from me then.
Another dumbed down effort to satisfy the minions :)
As for BTW, they provision the DSL network in the UK beerhunter...
Downinja
Very likely to be Static, I am with UKO LLU and mine is static (although you might have to request it).
Blocked ports are 80, 8080, 25 & 3128 (IIRC) which are basically web mail and proxy servers.
CG121
Hmm, no smtp/web/Active API servers then and no access to countless routers (remotely) on port 8080 :(
andykn
You get what you pay for...
Although Dynamic DNS may give you what you want.
CG121
Aint that the truth...
DDNS won't help though..
I wasn't bothered at the cost of the service, it just would've been nice to merge tv/broadband/phone into the one bill..Never mind.
Downinja
You would honestly leave remote router management on port 8080?
