$KY and wind
Discussion in 'Satellite TV, Sky TV & FreeSat' started by PIL, Mar 6, 2002.
  1. PIL
    PIL
    i live in a flat and our dish blew over recently - now fixed but i can only get about half the channels (ie No BBC but i can get ITV - booo and only 2 of the movie channels work!). can i assume from this that the dish isn't pointing quire right?
    BBC comes up with 'there is a technical problem with this channel' or some such.
    any help would be much appreciated,
    cheers,
  2. paiger
    paiger
    Yes. Call your local installer who will adjust it in 5 minutes.
    S
  3. gbmitie
    gbmitie
    Apr 25, 2001
    1,167
    49
    republic of ireland now
    +70
    But it will cost u. If u are anyway handy, check the lead on the LNB, might be loose or damp, have a look at other dishes and see how the are pointing, it only takes a fraction to lose signal. If u can't reach the dish yourself then call the man.
    gbmitie
  4. PIL
    PIL
    Ta for the advice, i got home last night and all was working - so i don't know if it came back itself or if someone fixed it.
    so until the next bout of windy weather....
