$ky and no signal
Discussion in 'Satellite TV, Sky TV & FreeSat' started by PIL, Nov 28, 2001.
  1. PIL
    PIL
    As a recent convert to $ky digital, all has been plain sailing until last night when I switched the box on and it says no satelite signal being received. I have checked the cable from box to wall socket (unscrewed and reconnected), booted up the box again and same thing.
    I live in flats and from the box, the cable goes up the outside wall and to the communal dish on the roof.I have called $ky (waiting for engineer) and the building managers say they will check the roof part, but this all takes time! (And no doubt they will all blame each other). Any suggestions as to where the problem may be?
    ie box cable or dish?
    I don't know which neighbours have $KY (so can't ask if theirs is OK) and we all have seperate cable runs up to the roof. Terrestrial and ITVDIgital work OK (it pixelates and breaks up but always has done)- they come down the same cable, the aerial is part of the same install as the dish.
    Cheers (All hail to the Ale etc.),
  2. Thor
    Thor
    Oct 18, 2001
    490
    Above UK
    I get no satelite signal being received sometimes when its raining heavy. I would suspect it is the cable or dish or lnb. If you have a new satellite box, its probably not at fault (the box).
  3. Garrett
    Garrett
    Apr 21, 2001
    43,623
    2
    167
    The best thief you'll never see.
    +8,385
    I get pixilation if there is a cloud anywhere in the sky. Mind you something has to be sacrificed so we can get 19 shopping channels.
    :cool: Ruby quartz shades
  4. Thor
    Thor
    Oct 18, 2001
    490
    Above UK
    rofl This is true!:D
  5. PIL
    PIL
    someone has f*cked the dish on the roof! as others in the block also have no signal!
    heads will roll....
  6. FRANTIC FRANC
    FRANTIC FRANC
    Aug 7, 2006
    1,375
    63
    +86
    Or the LNB has failed! Or multiplex box!
    Cheers, Franc
  7. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    Good find Franc, a thread from 5 years ago :rotfl:
  8. FRANTIC FRANC
    FRANTIC FRANC
    Aug 7, 2006
    1,375
    63
    +86
    LOl - Well I was bored! Cheers, Franc
