Quantcast
KWorld DVB-S 100 PCI Card
beerhunter
The above card is one of the supported tuners on MCE. Has anyone here actually manged to get the damn drivers to install under XP?
mehstg1319
Bit of a post resurrection here. But I wondered whether anyone had indeed managed to get the DVB-S100 working with 7?
I have installed the drivers and it is working (Almost) perfectly in it's own software (HD channels don't work even though H264 codecs are installed).
However when I try to use the card in Media Center, it recognises the card, but when a channel scan is done, it doesn't find any channels.
It did once find the channels, although when I tried to view the channels, they came up with the "channel off air or no signal" message on all but BBC1,2,3.
Any ideas
P
Edit. I have just noticed the original thread was for XP and not Win 7 - Apologies
