KV32FX68 - Which DVD Player?
Discussion in 'Blu-ray & DVD Players & Recorders' started by lilwashu, Jun 18, 2004.
  1. lilwashu
    lilwashu
    Apr 12, 2004
    870
    Southampton
    +15
    I recently bought a Sony KV32FX68 TV and it is very nice, except my Pioneer 525 DVD player displays a horizontal flickering band on the screen during most bright scenes. This seems to be a known problem between some Pioneer players and this TV so I figured oh well, it's 4 years old anyway so I might as well get a new one.
    Marantz DV4300 arrives and displays the same problem, albeit slightly less so. I have arranged for this to be returned. Like the 525 it works fine through S-Video. I tried my Xbox which plays with no flicker through RGB but is noisy and the picture is not great. I have tried swapping cables/sockets etc and my other sources are fine through RGB.
    So I need a DVD player (under £250) that will work properly on a KV32FX68 TV when using RGB SCART. I am currently looking at the Sony 930 and 730 players - I assume these will work OK? Are there some newer Pioneers that work OK with this TV (I am thinking 565)?
    Thanks for any suggestions.
  2. Jules
    Jules
    Oct 11, 2000
    5,585
    134
    +1,045
    I have a Panasonic recorder which plays discs to a pretty high standard and works well with my Sony 32FX68 (RGB connection).
    Might be worth thinking about. Particularly as the Panasonic E55 can be had for £220 if you look around!
