Quantcast
KV32FX68 Help
tulloch2003
Hi all what is the best way to get the best picture with this TV and a Philips DVD963SA. Component Video - Scart or Scart - Scart please.
Regards Tulloch
:confused:
P
Paul Atreides
Your TV does not have component input so RGB through Scart is best.
tulloch2003
Ok cheers for that scart it is then. So component from my player to scart on my TV won't work then:confused: .
Regards Tulloch
X
xyznicko
Does anyone know were I can download a manual fot this TV (KV32FX68) online?
P
Paul Atreides
Not exactly sure what you mean, I think you might be talking about a component to RGB converter.
In which case they're not worth it unless you have one already and can't get a refund.
P
Paul Atreides
I don't think that's a component to scart cable because it's described as having natural sound quality.
The picture is probably just to fool you.
P
Paul Atreides
Set your DVD player to output RGB and you will get best quality.
Similar threads
