KV32FX66 remote
Discussion in 'General TV Discussions Forum' started by Rizzo, Feb 28, 2003.
  1. Rizzo
    Rizzo
    Hello, I purchased a Sony KV32FX66 a little while ago and have recently been having some problems with the remote control (and yes I have checked the batteries!!) - Basically the TV stops responding to the remote and then after about 20 minutes or so it starts working again.
    The same thing happens when I use various universal remotes - so it's the TV itself that's not working...(though it has only happened twice so far)
    Has anyone else had this problem?
    ***rizzo***
    PS - my sony doesn't seem to buzz at all....
  2. Davo
    Davo
    Mar 20, 2002
    12
    I had the same problem with a philips widescreen... it eventually got worse and worse. Not sure if this is the same fault?
    I assume your TV is still in warranty, so I'd get it checked out.
    Davo.
