KV32FQ86 picture settings
Discussion in 'General TV Discussions Forum' started by ventoboy1000, Aug 18, 2004.
  1. ventoboy1000
    ventoboy1000
    Hi, please could owners of this particular tv let me know what their picture settings are ie contrast, brightness etc.
    Much appreciated !
  2. HowieC
    HowieC
    Jun 9, 2002
    251
    London
    There will be a lot of variation from set to set, but for the record.....
    C62 B52 S16
    However I had to adjust G2 slightly internally to achieve a true black.
  3. ventoboy1000
    ventoboy1000
    Hi Howie, thnks for your reply.
    Please could you explain further with regards to variations in set to set as I have noticed that with my first FQ86, the picture settings were spot on and I didn't need to adjust them.
    This one that I have needs the brightness adjusting from default value of 50 to 54 to bae able to see everything clearly, ie default settings give a very dark picture.
    Engineer said that there should not be such variations from set to set.
    Service mode settings are as follows :
    Bright expand is 300
    Bright center is 27
    Contrast max is 54, default value is 59
    Any help would be much appreciated
