KV32CS70 Service Default Settings
Discussion in 'TVs' started by kingfish, Dec 18, 2004.
  1. kingfish
    kingfish
    Dec 18, 2004
    54
    +5
    Ok, I realise I'm a newbie and have made a big mistake :oops: so please forgive me in the first instance.
    I wasn't happy with the picture with my new KV32CS70, I'm experiencing a slight out of focus type problem with my set on RGB signals, dvd, sky etc. On reading that the set was essentially the FX68 I followed the posted service settings for that set, only to find that it's not quite the same at all! Yes I was silly for not writing down the values. I know :nono: but all I need is the default settings if somebody can send them to me or post it, as I don't believe there's a way to return to the factory settings?
    Please, take pity on my uselessness.
  2. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    The settings are set specific. Sorry to be the bearer of bad news, there isn't an easy way out of this as far as i know.
  3. kingfish
    kingfish
    Dec 18, 2004
    54
    +5
    Thanks Lynx, the picture isn't that bad to be honest, seems to be quite straight, no pin cushioning really, I'm just a perfectionist! If anybody wants to send me their default setting so atleast I'd be a bit closer.
    I always seemed to get a slight ghosting, and the xbox it would manifest itself as a colour outline on the right side of objects on the screen. I thought it could be a RGB colour inbalance but that didn't seem to make a difference. I've got the settings for those though, I just got a bit adventurous and waded in too deep.
  4. DJ Mike
    DJ Mike
    Nov 25, 2004
    412
    +19
    What settings are you after in particular? As already mentioned every set has its own "natural" defaults - but at the very least I can provide you with some figures to work from, and maybe that'll solve your problem.
    I myself have been messing with my set's geometry - I've managed to get it to the point where all input sources are fairly well balanced - unfortunately if you have multiple picture sources as I do (games consoles, DVD, etc.) then you can never have a perfect setting that is going to work for all consoles - so you have to find a balance.
    Unfortunately my Xbox is still suffering from a flickering issue - I'm wondering whether to bite the bullet and purchase an official Microsoft RGB SCART lead and use that instead of the third party one I have, but I have a feeling that isn't going to solve anything.
    M;.
  5. kingfish
    kingfish
    Dec 18, 2004
    54
    +5
    Actually that would be quite nice to have a nice balanced one even if each set is individual. I don't really get a flicker issue with the xbox but there is a clear left to right ghosting shadow visible.
    Could you send me yours? I know it's a bit to ask but I'm sure I could return the favour some day. :clap:
