KV28FX65 Wavy Right Hand Picture
Discussion in 'General TV Discussions Forum' started by bugfinder, Mar 21, 2002.
  1. bugfinder
    bugfinder
    Help!
    A mate recently bought a Sony KV28FX65 and when connecting DVD through 3 RCA to Scart into AV1, the right hand side of the picture is wavy - only really noticeable on Channel 4 though. (Reception is fine)
    If he unplugs the scart it seems to clear the problem????!
    The player is a Pioneer surround sound. When in standy the problem occurs but when the scart is unplugged from the tv it clears.
    Is this a fault with the TV? Has anyone else noticed this?
    Would connecting into another AV socket improve things?
    I had the same TV connected to a Sony DVD player and did not notice this problem.
    Any advice appreciated.
  2. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    Just guessing, but the DVD player Scart cable might be a cheap one with poor shielding? Is it a cheapo Scart cable?
  3. bugfinder
    bugfinder
    It's an Ixos cable, and as the other channels are fine we eliminated it... it only occurs on Channel 4??!
