kv-32fx65U Sony TV blinking
Discussion in 'General TV Discussions Forum' started by myavforum, Mar 28, 2003.
  1. myavforum
    myavforum
    My Sony kv-32fx65U TV has started to blink a cuople of time during a program at regular intervals, they do not last long, less than 1/2 second with a longer gap between each blink. has anyone seen this problem and how can I resolve it or what might be causing it? It happens occasionally on DVD playback as well as normal NTL channels. The only common thing between them is that both are view via scart sockets.:(
  2. big10uk
    big10uk
    How Many times is it Blinking ?
  3. myavforum
    myavforum
    Thanks for asking, after a lot of ping ponging between NTL and SONY the store from where I bought the TV said that NTL were transmitting a signal that make the TV want to switch between wide screen to normal etc.. and that it would be best to turn off the auto feature on the TV, since they did this it has not blinked at all, not that I have noticed any way.
    to answer your question it was once between each change of screen ratio's.
