kv 32fx 66
Discussion in 'Televisions' started by Adrenochrome, Jan 24, 2003.
  1. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    got my dav s300 back from being chipped today:D just wired it up to my new kv 32fx66:D and the sound volume is really really low:(
    i used to listen to tv through dav s300 at volume = 10 now i have to listen to it at volume= 30 does anyone have any ideas how to get it back to the way it was?
    when i listen to a dvd i listen at volume= 14 which is the same as usual
    my old tv was a hitachi c28w510sn.
    regards
    Tom Barr.
  2. Rookies
    Rookies
    Jan 4, 2003
    4,894
    103
    +344
    Hi Tom
    have you manage to do that favour for us as discuss by e-mail?
    Now down to dvd, is there a volume setting on your DVD player? I aint sure as I never had a DAV. I i just assume with it having speakers there be volume settings on the dvd player aswell??
  3. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    what favour? what email?
    the volume levels i am talking about are the dav s300
    regards
    Tom Barr.
  4. Rookies
    Rookies
    Jan 4, 2003
    4,894
    103
    +344
    I think I may of got you mixed up with someone else that i have been talking to by e-mail regarding Tv settings etc.
    Anyway is there no volume on your Dav dvd player that may of been altered when been modified?
    as this might be why it low?
  5. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
  6. w3dal
    w3dal
    Aug 4, 2002
    4,801
    Chelmsford, Essex
    +509
    Have you checked the scart lead between your DVD player and TV?? i have this TV and the SONY NS405 DVD player and at 30 its way to lould. Maybe a setting on the DVD player has changed since the chip was installed???
    Whats the sound level like when watching a TV channel or a music channel on Sky using one of the other scart inputs???
    Also if your using the phono output of the TV to your Amp then you need to turn the TV speakers off in the Menu and then turn the volume up a little bit which should help the volume problem on your amp.
    Let me know!!!
    Dal
  7. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    thanx for the reply
    i had found out that my wife had put the phono leads into my dav s300 to my tv instead of from my dav s300 to sky digital:mad:
    Tom Barr.
  8. TommyP
    TommyP
    Nov 7, 2002
    63
    Maidenhead, Berkshire
    Think that may of been me m8. I'm sorting aout your request as I type.
    Tom :D
