KV-32CS70 "color line" at top!
Discussion in 'General TV Discussions Forum' started by t3ch, Feb 8, 2005.
  1. t3ch
    t3ch
    I have an realy anoying "color line" at the top of my KV-32CS70.
    [​IMG]
    or better seen on movie.
    Movie
    Can i fix this within service menu? the suport said that the line should be there and is on all KV-32CS70, but i strongly doubt it.
  2. DJ Mike
    DJ Mike
    Nov 25, 2004
    412
    +19
    That line is indeed present on all Sony KV32CS70 televisions - as has already been reported by myself and others here - whether you can see it or not depends how lucky you are with your factory settings
    You can fix it by adjusting V SIZE in the Geometry menu in the service menu - there are plenty of threads here about getting there - just search around a bit.
    M;.
  3. t3ch
    t3ch
    thx for replay. i have changed the v possition but that kinda screws the whole thing. i will try v-size when i come home from work.
