KV-32 FX66 input (signal symbol appearing on screen)
Discussion in 'TVs' started by ianpeter, Jan 20, 2004.
  1. ianpeter
    ianpeter
    Is there a way to get rid of the symbol on the top left hand corner of the screen that indicates the type of input signal.
    It is really annoying. Its been a year now and I can't figure out how to do it.
    I am praying that someone out there can help me:(
  2. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    Try this. . .
    On your remote control look for a button that looks like a small TV screen with a "+" sign in the top right. It might also have the letter "i" .
    Press this and wait a couple of seconds. This should display channel info, input etc. If you press repeatedly the display should disappear.
    Hope this helps
  3. ianpeter
    ianpeter
    Thanks warpaint. I can't believe I didn't think of using this forum before to get help.
