kv-28fx65 u what is AV2 Output
Discussion in 'General TV Discussions Forum' started by sony_tv, Jan 24, 2008.
  1. sony_tv
    sony_tv
    what is the AV 2 Output setting in the Menu?
    It has valid values of:
    TV
    AV1
    AV2
    AV3
    AV4
    can someone please explain to me what these settings do.
    thanks
    :lease::hiya:
  2. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    AV2 is configurable to output whatever signal is being inputed on the other AV sockets and also the in built tuner on the TV. If you connect a DVD recorder to AV2 you can then specify which signal goes to the recorder. So if you have SKY on AV1 you can output the signal to AV2 so you can record it,
  3. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    These select the various inputs. I believe your set has 3 SCART connections as well as S Video. An AV2 connection is usually the one you might use to connect, via a SCART lead, to a DVD or Video recorder. Usually when you switch on these devices the connection to the appropriate AV will kick in automatically. You can over-ride this manually using the menu. As you can see they also output a signal which can be used by other devices.
  4. zircon3035
    zircon3035
    Feb 23, 2005
    513
    46
    Uncertain
    +156
    The AV2 out feature is also useful to dealers and showrooms. For example if you set AV2 out to provide AV1, you can daisy-chain TVs so that whatever is connected to AV1 (demo DVD for example) is passed out of AV2 to the next TV in the chain.
    HTH
    Ian
