kuwait
redhat
Ive just moved from the uk to Kuwait.
was thinking of hooking up a pc with a pci satellite card and a dish to try and receive uk freesat channels.
Is this Possible?
What do i need / best way to go about this?
Any other options?
is there a current thread for this?
im technical but this is not my game advice would be cool
cheers
glenn
logiciel
Hi and welcome to the forum.
That would be free satellite channels that you're looking for, not Freesat, otherwise you wouldn't have posted immediately below this request from forum admin:
http://www.avforums.com/forums/satellite-tv/411852-if-your-topic-freesat-sky-do-not-post-here.html
Here are the details about Freesat: freesat - Subscription free HD Satellite TV through a Digital Box.
The maps on glt's link show the situation about free satellite channels, as does the text if you have the language.:)
Others in your locality from the UK will be able to advise you on how they get their fix of channels.
grahamlthompson
I thought the pictures really didn't need any text at all :rotfl:
logiciel
Quite right - I was just giving OP a hint as to what the text is about.:D
grahamlthompson
On reflection Arabic would have been more appropriate :)
logiciel
From Scandinavia to the Persian Gulf is quite a big jump.:)
C
cyprusstudio
Your best option to receive UK channels in Kuwait would not be satellite as there is no satellite signal where you are.
You can receive them through your computer. You will need to set up a UK VPN Tunnel, not as complicated as it sounds, so that you IP Address appears as though you are in the UK. You will then be able to use BBC Iplayer, ITV Player, TVcatchup, Filmon, though the latter is available without the VPN.
Find a VPN provider such as BlackVPN, and you will be given the information to set up your computer, including instructions and account details.
You can get leads to connect your computer to your TV.
Hope this helps.
Chris
Similar threads
